Assembly extraction path
khimani_mohiki
I want to find the best path to assemble or dis-assemble a part into an Assembly, for occasions where you know the part will physically fit you just don't know what sequence of rotation/translations are required. Is there anything in Creo to do this, I know its possible in NX and CATIA so I assume it should be possible in Creo. Any help much appreciated.
1 REPLY 1
I doubt that this is possible.
Martin Hanák
