Auto-populate a Revision History table
jpratt
I have a requirement to auto-populate the Creo Parametric revision history table on drawings from the Windchill information (Revision, Modified By, Modified On, and Revision Description (IBA)). The Revision Description will also be a Creo parameter.
The requirement is there needs to be intelligence so that when the drawing is revised from revision 0 to revision 1, the revision history information for revision 1 is automatically applied to the next row of the revision history table from Windchill, and the revision 0 information is maintained on the drawing. The same will be true for all new revisions after that. Once the drawing is revised to revision 7, revision 0 is dropped from the revision history table, all other revision history information is shifted down one row, and then the revision 7 information is added to the last row; and so on for all revisions after that.
Does anyone have any thoughts or ideas on how to accomplish this?
3 REPLIES 3
Chris3
(To:jpratt)
We looked into this. It can't be done currently. I opened an idea for it here:
https://community.ptc.com/t5/Windchill-Ideas/Add-Windchill-parameters-for-latest-change-number-and-where-used/idi-p/470362
Ultimately though I convinced the organization to eliminate the revision block entirely and instead now we just have a statement where it used to be that says something like revision table is available upon request in Windchill.
Grace2K
(To:jpratt)
It can be easily done using parameters and some relations to create a shift register.
I assume PTC_WM_REVISION, PTC_WM_MODIFIED_BY, PTC_WM_MODIFIED_ON are environment parameters coming from WC.
Create the following parameters (string type) to trace the last 3 revs and shift them when a new rev occurs
RV_REVL_INDEX
RV_REVL_DESIGNER
RV_REVL_DATE
TEXT_CURRENT_REV
RV_REVS_INDEX
RV_REVS_DESIGNER
RV_REVS_DATE
RV_REVS_TEXT
RV_REVT_INDEX
RV_REVT_DESIGNER
RV_REVT_DATE
RV_REVT_TEXT
Where REVL, S, T stand for Last, Second-last, Third-last.
RV_REVL_INDEX must be set as default in your template to "00" or the default text corresponding to the text of your base revision.
Then add the following relations in your part/assembly:
IF RV_REVL_INDEX != PTC_WM_REVISION
/* begin shift register */
RV_REVT_INDEX = RV_REVS_INDEX
RV_REVS_INDEX = RV_REVL_INDEX
RV_REVL_INDEX = PTC_WM_REVISION
RV_REVT_DESIGNER = RV_REVS_DESIGNER
RV_REVS_DESIGNER = RV_REVL_DESIGNER
RV_REVL_DESIGNER = PTC_WM_MODIFIED_BY
RV_REVT_DATE = RV_REVS_DATE
RV_REVS_DATE = RV_REVL_DATE
RV_REVL_DATE = PTC_WM_MODIFIED_ON
RV_REVT_TEXT = RV_REVS_TEXT
RV_REVS_TEXT = TEXT_CURRENT_REV
ENDIF
In case of a new revision just write in TEXT_CURRENT_REV the description of the current revision.
Create a table or a note in your drawing writing your preferred parameters order.
I used the following where the last rev comes always to the top of the list.
RV_REVL_INDEX   RV_REVL_DESIGNER   RV_REVL_DATE   TEXT_CURRENT_REV
RV_REVS_INDEX   RV_REVS_DESIGNER   RV_REVS_DATE   RV_REVS_TEXT
RV_REVT_INDEX   RV_REVT_DESIGNER   RV_REVT_DATE   RV_REVT_TEXT
This is just an example, you can customize it as you want.
In case you want to trace 4 or 5 revs the trick is the same. Just add 1 or 2 new sets of parameters (4th to last, 5th to last) and add them in the relations of the shift register. You use the revision text coming from WC, just identify the corresponding parameter and include it in the shift register instead of TEXT_CURRENT_REV. I used this method in many PDM/PLMs. It always works well.
HannesBuxbaum
(To:jpratt)
Creo seems not to have built-in functionality for maintaining such revision history tables.
I can not recommend the releation-driven approach: you have to fiddle around with parameters in releation code. Disadvantage: write and maintain such code within each models/drawings.
What works much better is a seperate TOOLKIT application that examines the model/drawing right after retrieval and/or before save to check for changes, manage a rolling table, etc..
(We, PDSVISION offer such a tool, but encourage to maintain revision meta data not in parameters/drawing tables but in Windchill.)
