Hi, I'm a new users of Creo 11.0.2.0
I have set in my configuration (view the attachments) the option "Automatically Scaling a Sketch" but it's not work. Are there some other configuration to able or disable?
Thank you
uploaded video autoscale.mp4 shows that in my Creo 11.0.2.0 the example from youtube works well.
Suggestion:
Note: You can upload part containing problematic sketch. Pack part file into zip file and upload zip file.
please explain what you expect and what Creo does. I need to know the difference between reality and expectations.
My expectation is "https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/part_modeling/sketcher/About_Auto_Scale.html"
but if I sketch a rettangle and I change one dimension, the other dimension does not scale like in the video (see the attachment).
I try to sketch other shape but the result is the same.
Suggestion:
Works as expected in Creo+ (12.1). This only applies to the first weak dimension, in the first sketch, that is changed. It also does not apply to an added dimension.
