Axis Display in Drawing
PaulMailloux
Hey Folks
Got a simple one here, but I guess the brain is working just yet...
WF5 M080
After doing a Show of an axis, typically I want to drag both endpoints
around to get the proper overhang of the geometry/view on each end.
It seems I can't drag each endpoint of the axis independently, as I drag
one end, I lose the location of the other end...
Is there some keystroke needed to anchor one end as I drag the other
end?
Paul
Paul Mailloux
Cad/Cam Applications Engineer
NyproMold Inc
144 Pleasant Street
Clinton MA 01510
Phone: (978) 368 - 4598
Fax: (978) 365 - 4548
www.NyproMold.com
2 REPLIES 2
Thanks all but I just figured it out.
It seems you need to do an Update Draft or Regen Model first then I can
freely drag the endpoints.
Makes me wonder about a config option that I may have set. I believe
there is an option NOT to regenerate drawings at opening, which was
helpful for very large drawing retrievals. I may be using this option
and therefore causing this problem. Need to dig a bit.
Paul
Paul Mailloux
NyproMold Inc
144 Pleasant Street
Clinton MA 01510
Paul,
It's a bug and fixed in M090.
You can hold down your alt key down pick then pick axis then drag.
I tried your method you found at it looks like if you are in the review tab the axis drags fine.
Brian
