I am trying to get Bill of material of an assembly but unable to do that and always getting an error as attached below
Anyone has any suggestion for that ???? What kind of output file is missing ??
Using Creo 2.0 M110 version.
Yogesh
maybe you do not have rights to write a file into current working directory.
MH
Hi Martin,
I do not think so because already got the full admin rights for special purpose and working directory is in my local drive on my system.
YG
Yogesh,
As Martin mentioned, Write permission is one of the common reasons for this. You may try changing the startin directory for Creo and test this out.
Right Click on Creo Shortcut > Properties and change Startin to a folder in your login (where you all permissions)
Look in your working dir for file named (assembly name).bom. If it's not there, then they're right.
How re you outputting the BOM anyway? It directly from Creo like below?
Yes Hatim, Outputting by same way as you mentioned and I haven't found (assembly name).bom in my working directory.
