I have two parts (call them Part 1 and Part 2) within my BOM that are used in two different positions in the assembly. My BOM calls out Part 1 and Part 2 twice:
QTY PART
1 Part 1
1 Part 1
1 Part 2
1 Part 2
How can I merge the rows together so that there is one row for Part 1 and another for Part 2, each having a quantity of 2?
QTY PART
2 Part 1
2 Part 2
Could this be fixed using the repeat region?
Go to table - repeat region - attributes and select No dup/level.
If you are using flexible components, these have historically been a problem for repeat regions.
Thank you, that worked great. However, the index numbers changed. It used to be:
INDEX QTY PART
1 1 Part 1
2 1 Part 1
3 1 Part 2
4 1 Part 2
After merge:
INDEX QTY PART
5 2 Part 1
6 2 Part 2
How do I change the index values to:
INDEX QTY PART
1 2 Part 1
2 2 Part 2
