I work as a student in a company which needs a new type of BOM table. Specificly I have to sort a piping assembly by pipes, fittings, etc. It was pretty easy to create a new table with this filtering, but now i have 5-6 different region and each start indexing items by 1. And this is the problem: I want a continous indexing, not one which starts every region from 1.
Thanks you in advance,
-Laci
(fun fact: We have already a table with 2 region and a countinous index, but nobody knows how they made it :'D )
I found out that I can set the starting index from the previous region with RepeatR->Attributes->click on region which i need->start index->click on last index from the pre. region->OK
