Background Color for Print Preview
pgorman-2
2-Explorer
I know its pretty easy to set the background color in Creo 3.0. When I have it set to ... lets say blue, and then do a Print Preview, in the drawing package, the background automatically switches to white ... anyway of over-riding this?
3 REPLIES 3
according to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS197191 it is a software bug. Software fix expected for Creo Parametric 3.0 M090 using set_plot_background_color  to yes
MH
Martin Hanák
Thanks Martin ... I found the same answer 10 minutes after posting ... I guess I need to search more before posting. Thanks again for your help.
Hi Patrick,
If you wouldn't mind, can you please mark Martin's reply as the Correct Answer.  That will help close the loop and provide other users with an answer, when they search.
Amit
