Hey Antonius (if your out there today).
I have a basic dimension (and I have also tried it with the neither option - as shown) that I have added a GD&T tolerance box - manually.
The two boxes overlap (using either the neither option or the basic option). If I put a return between them, then there is a space between the boxes.
Does anyone (I know Antonius is the drawing Guru) have a suggestion or do I need to separate them into separate annotation.
Dale
Oh, that's new! Enhancement? ![]()
Easy fix thought, change the text style line spacing to 1.0
I figured you'd know what was up. It's just one of those things you don't deal with everyday. Besides why would my predecessor change it to less that one. Thanks a bunch.
Is there something to change in the config.pro or drawing.dtl file to set this?
I think this was one of the few that didn't make it to the detail.dtl config options.
You can change the default text style in the session but I am not sure if it saves it outside the current drawing, or even if it remains with the current drawing.
Annotation>Format>Manage Text Styles>"default">Modify>uncheck line spacing and enter 1.0.
Subsequent text will be created with line spacing at 1.0 and "default" unchecked in the annotation style dialog for the newly created annotation features.
