Basic Measuring?
ptc-4594446
7-Bedrock
Basic Measuring?
Hi planetPTC,
I am creating an object, and I need to put in indents for fitting other pieces in.
I go to extrude -> placement -> define -> then I select the face, draw the rectangle, but it won't let me dimension and change the size on my sketch.
Any help is great.
Thanks.
6 REPLIES 6
KrisR
(To:ptc-4594446)
PLease upload your model so we can assess what is happening!
I have worked it out by creating a large rectangle and then shortening it.
Here is the file, all I was trying to do was center it.
KrisR
(To:ptc-4594446)
I can't open it because you are using schools edition unfortunately. It sounds like you might have use of the "symmetry" constraint. Take a look for that in the help file and perhaps this will help?
VladimirN
(To:KrisR)
You can open it to view this model by using (for example) Creo View Express (http://www.ptc.com/products/creo/view/express/).
Kevin
(To:ptc-4594446)
A screenshot of what is happening on your end might be helpful. Openning the file I don't see any problems like you're describing just an incomplete analysis feature.
I am now using creo parametric 1.0 schools edition and haven't had any trouble. Thanks
