Bend line manipulation in drawings question
HI,
I have a part that you can see below. I created 2 flanges and joined them together with a planar feature. It works great in the model. Now when I am creating the print, the bend line is a single bend line across the part, which makes sense since it really should be bent at the same time. However, I want to delete the part of the line that is going over the part that is not being bent because I'm pretty sure that at some point, one of my brake operators is going to see the line all of the way across and bend up the flat part too. I can't get two bend lines to show up, and I can't get the sketch features to snap to the line in the drawing. Any ideas on how to make two separate lines in the drawing?
Brandon
