Best way to import STL or OBJ files
cgherghe-2
Is there a best way to import STL or OBJ files (mainly used for 3D printing) in CREO Parametric?
I was not able to get parts with a smooth finish by using the OPEN function, those little triangles do not translate well to a nice finished surface, they look really ugly and blocky after I export/save them using the Shrinkwrap option.
Even on level 10 for Shrinkwrap they still look awful in the end! Wish they had level 100 in there...
Is there a better way to obtain a CREO part starting with an STL or OBJ file?
Thank you!
(I really hope I chose the correct location for this message)
Hi @cgherghe-2
Have you tried Freesyle Reconstruction on the imported model?
To Reconstruct Shapes from Facets
-Thanks
Hi @cgherghe-2
-Thanks
No, I do not know how to use that feature...
Any tutorials out there that you might be able to recommend?
YouTube or PDFs, I will go through them!
Many thanks!!!
Important information !!!
At the end of the video, its creator informs that user must have:
Free Style license + Topology Optimization license
-OR-
Free Style license + Reverse Engineering license
Topology Optimization and Reverse Engineering licenses are not part of the basic Creo licenses, they must be purchased separately.
Martin Hanák
Hello @cgherghe-2,
It looks like you have some responses from a community member. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
