{Blank Subject 2010-03-22}
davehaigh
I added an axis to the hole, and set that axis in the model to be attached to the dimension. After adding a gtol to the dimension, the datum is now attached to the dimension, but it's centered on the length of the text in the dimension line.
When moving the datum so it's under the gtol, a tail is left, and I can't move the tail.
See attached image.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
3 REPLIES 3
Pro Gurus:
Does anyone have an MS35333-70 or tabulated star washer modeled in WF3 build
M150 and don't mind to share?
Thanks in advance for your time and help.
Frank
Thank you all for your help.
I have a tabulated Pro/E model from Anthony, a link to a McMaster step file
from Robert and a
Tom
The most bang for the buck...
Try either DELL or HP or whatever line on computers your company uses the most and do a search for refurbished or scratch and dent computers.
Many of these have been purchased and opened then returned to the seller. They can't sell them for new, but you get the same warranty.
The M6300 I'm using now I saved about $2500.00 over new price.
Paul
I'm not trying to start a debate on this but I've been a contractor or THE temp for over 30 yrs. And I have seen that in most places. But if you are bringing in a contractor at $50 to $60 and hour, that means your paying the contract house around $85 to $90 an hour.
It really depends on what the contractor is being brought in for. If they are going to be handling or managing large assemblies or some of the more complicated work then it's better for your budget to put as fast a computer in front of them as possible.
