Hi Ryan,
I use the 64-bit version of Pro-E WF 3.0 and have shared the files with 32-bit Pro-E users without problems. I cannot speak for WF 4.0 & 5.0, but there should not be a problem sharing CAD files between 32-bit & 64-bit systems.
A problem 64-bit users occasionally experience when switching to 64-bit systems is the lack of drivers for older software, such as printer drivers. I had a problem with the PDF driver for QuickBooks Pro until I upgraded to the 2008 version a few years ago.
In Reply to Ryan Crisp:
Proe Users,
Are Wildfire 4 & 5 files cross compatible w/ 32-bit & 64 bit systems?
SolidWorks 2010 is a memory hog and is forcing me to move to 64-bit but I
need to verify that I will not have any compatibility issues with Proe files
for clients that are operating on 32 bit systems. If they are not compatible
are there any software utilities offered that will convert the files? Or is
this wishful thinking J
Dell Precision M6500 Intel(R) Core i7 2.67GHz 4MB RAM
Ryan Crisp | Senior Mechanical Engineer
Priority Designs
501 Morrison Rd.
Columbus, OH 43230
(614) 337-9979
< www.prioritydesigns.com
CONFIDENTIALITY NOTICE: This email along with any attachments contains
proprietary information, some of which may be legally privileged. If you are
not an intended recipient of this email, you must not disclose, copy or take
any action in reliance of this transmission. If you received this email in
error, please contact the sender and permanently delete all copies of the
email and any attachments.
