Brain Fart
cying
Brain Fart
I have a part that someone else designed and It has draft angles etc. Basically I want to do is copy the highlighted surfaces to a new part so I can convert it to a solid part .
Is there an easy method without creating an assembly and use the data sharing feature?
[cid:image001.png@01CFDF23.0657A3D0]
10 REPLIES 10
RandyJones
20-Turquoise
(To:cying)
One method is to use an external copy geom feature. In Creo Parametric 2.0 this is Model Tab | Copy
Geometry (from the "Get Data" group)
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
cying
(To:cying)
I should've mentioned that I am on Creo/Element AKA WF5
TomU
(To:cying)
The same functionality is there. Insert, Shared Data, Copy Geometry. Open the reference model (the one in the picture below), determine where to place it (default is probably fine), and then choose the surface(s) you want to copy.
Tom U.
cying
(To:cying)
Thanks for the quick replies 🙂
I was hoping not have to create an blank assembly to do so. Here's what I did:
* Create a blank assembly
* assembly the reference component
* create the new part by using INSERT -> COMPONENT -> CREATE
* Activate the new component and select INSERT -> DATA SHARING -> COPY GEOM -> Select the surfaces
RandyJones
20-Turquoise
(To:cying)
On 10/03/14 15:52, Ying, Calvin wrote:
> Thanks for the quick replies J
With external copy geom you don't create an assembly. You do this:
* Create a blank part (using your start part)
* Insert | Shared Data | Copy Geometry (per Tom below)
> *From:*Uminn, Tom [
> *Sent:* Friday, October 03, 2014 4:25 PM
> *To:* Randy Jones; 'PTC/USER User'
> *Subject:* [proecad] - RE: Brain Fart
> *From:*Randy Jones [
> -----End Original Message-----
> Randy Jones
> 1525 E North St
> PO Box 5060
> email:- <
">mailto:->
> Phone: 785-823-3276
> Fax: 785-667-2695
> ********** CONFIDENTIALITY NOTICE ********** The information in this email may be confidential
> and/or privileged. This email is intended to be reviewed and used only by the individual or
> organization named above for the explicit purpose of conducting business with Trans-matic Mfg. Co.
> If you are not the intended recipient or an authorized representative of the intended recipient,
> you are hereby notified the any review, dissemination or copying of this email and its
> attachments, if any, or the information contained herein is strictly prohibited, and no privilege
> or protection has been waived. If you have received this email in error, please notify the sender
> immediately by return email and delete this email from your system.
Randy Jones
1525 E North St
PO Box 5060
email: -
Phone: 785-823-3276
Fax: 785-667-2695
cying
(To:cying)
Got it, awesome. This what I was looking for, thanks!
bokm9606
(To:cying)
If you have AAX (Advanced Assembly Extension) you can, in the *parent* part
- at the end of the model tree (recommend highly to perform at end of model
tree):
1. create a surface copy feature of the surfaces you want
2. then create a "publish geom" feature selecting all quilt created in the
parent part
In the *"target"* part:
1. create a copy geom feature - selecting the parent part and its publish
geom feature created above as its source
If needed you can super-position the geom via CSYS mating
bokm9606
(To:cying)
keep in mind you need AAX extension to perform some COPY/ Publish geom
features. If the features appear "grayed out" most likely you do not have
the extension.
On Fri, Oct 3, 2014 at 1:59 PM, Ying, Calvin <->
> *From:* Randy Jones [
TomU
(To:cying)
You don't have to have an assembly at all (assuming you have the advanced assembly license). You simply insert the copy geometry feature right in the empty part and reference the other part. No assembly required.
DonSenchuk
(To:cying)
For those following along, if one doesn't have AAX this can only be done using an assembly. If I Remember Correctly, of course.
