Bundle too thin
Pettersson
Bundle too thin
Anyone encountered this?
I have five pretty massive bundles of wires, each with a diameter of about 8 mm, coalescing into a single bundle. I put on one bundle with 1 mm wall thickness to represent the shielding, then bundle that again with a shrink tube (also about 1 mm wall thickness) The resulting bundle has a diameter of 13 mm. This is not reasonable, and I can clearly see how the five bundles overlap by a lot as they enter that one superbundle.
Does anyone know a fix for this?
Never mind, I realized the issue. The five bundles stop at the entrance to the big bundle. So there is no overlap between them. That means all the wall thicknesses of the five bundles disappear and the individual wires are grouped much more efficiently. Makes sense.
