CHANGE THE I BEAM SIZE IN AFX BY
RAJENEESHMISHRA
How can I change the I Beam size Top & Bottom Like that Top size 500 & bottom size 650 in Creo AFX Libraury.
Can you help me.
With Regards,
Rajeneesh Mishra
Hi @RAJENEESHMISHRA
threre is an in depth video on how to customize the library here:
https://youtu.be/-iLYU-YT8e4?t=431
At minute 14:30 you can see the editing of a tab file for an I-Beam. Here is also the point where you would add your own lines with custom sizes. Just stick to the existing format and add the sizes that you want.
I hope this helps.
Greetings Sam
Samuel Brantner
B&W Software GmbH
In our B&W Webinar Week 2020 there were various presentations, which we would like to provide here, too. In "What's new in AFX?" you will be introduced to the latest features of Advanced Framework Extension. For more information about the software, please use our contact form on the website: ...
6 REPLIES 6
Hi @RAJENEESHMISHRA
I hope this helps.
Greetings Sam
Samuel Brantner
B&W Software GmbH
Thanx for support.
Dear sir,
I want learn the relation and parametre concept in creo.
but I have many time of study in help centre, but we are not understanding the relation and parameter in creo 7.0.3.0.
how can create the relation and parametre in basic level.
Hi @RAJENEESHMISHRA ,
sorry, but I don't understand the question here. If you refer to the param_relations.txt file of AFX you can find the information in the help center:
AFX Configuration: To Add a Relation File (ptc.com)
Greetings Sam
Samuel Brantner
B&W Software GmbH
Can you to told me how many total command in advance assembly.
what is the Creo normal assembly difference between to advance assembly.
This comparison document is a little old but it hasn't changed much. It shows the added features of AAX (advanced assembly extension)
https://boundarysys.com/wp-content/uploads/2020/01/Creo-Advanced-Assembly-AAX-Comparsion-Document.pdf
