CREO 10, WIRE LOOM ROUTING IN CABLING
Charles421SD
I am working in Creo 10 Cabling of which I am still in the early learning phases. I am able to route multiple cables in my assemblies but now I'd like to know if it is possible to create generic Wire Looms that would surround them along their paths. I would prefer to create this before any routing so that I could use it to follow its route when creating new cables in my harness. Is this actually done in "Sheathing" in the new cable routing window option or maybe as a spool and if in a spool, how do I enter the ID diameter as well as the wall thickness?
Thank you.
3 REPLIES 3
You are in the wrong forum.
PTC has two CAD systems:    Creo+ and Creo Parametric    and     Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
To move your post, click on the three vertical dots on your initial post and click on "Notify Moderator".
http://kotom.eng.free.fr
Hi @Charles421SD
As per @Kotom-Eng's reply, I have moved your topic to the Creo+ and Creo Parametric discussion board.
Best regards,
Catalina
PTC Community Moderator
PTC
Hi @Charles421SD
Thank you for your question.
Best regards,
Catalina
PTC
