Gurus,
How do you enter a negative angle without edit definition and how do you get it to stay (mine flips on regeneration)? On the image shown if I modify/edit the shown 45 to -45 or 315 it does not move. However if I edit definition it will. But it seems to flip around unexpectedly after a full regen. I remember this being an issue when using datum planes because planes have two sides but this is a solid planar surface. Has anyone cracked this code or can provide a good rule of thumb for rotating in both positive and negative directions?
BTW: The assembly constraints are planar coincident, axis coincident, and angle offset.
CREO 2.0 m110
Windchill 10.0 m030
Eric
