CREO assembly drawing x-hatching problem with save-as PDF
DCG
We've been having a problem lately with assembly drawing x-hatching not looking correct after save-as to PDF.  This seems to have happened since maybe CREO 9, possibly earlier.  But it seems to get worse with each release.  It starts out with an assembly drawing with x-hatching.  It looks fine.  But when we save-as to PDF, the x-hatching looks messed up.  I have attached some screen shots of the PDF showing x-hatching not looking correct.  This is not the only drawing it happens on.  It happens   Currently using CREO 10.
Thanks in advance.
MartinHanak
(To:DCG)
I think you have to publish pictures of Creo window containing specific drawing, too.
Martin Hanák
DCG
(To:MartinHanak)
The drawing in CREO before saving to PDF.
MartinHanak
(To:DCG)
it seems to me there is an interference between components in the assembly.
Just for testing purposes ... can you hide interfering components and generate PDF?
Martin Hanák
DCG
(To:MartinHanak)
I hid the two threaded components.
However, if I hover over it, it shows the correct hatch...
