8-Gravel
May 26, 2022
Sketch in creo 9, Project command
  • May 26, 2022
  • 4 replies
  • 6994 views
I try to understand, why, in Creo 9.0, the the sketching, the Project have been changing.
The new way to select the line to project is longer to work with it.
In the past, we chose Sketch Complete loop, and we chose each line one after the other.
Now, we have to chose one line, chose chain, then chose the Rule-Based, then the rule we want, ok, and to finish to tell the command that we want to create the geometry...
A work that will normally have taken maybe 30 minutes to extrude in solid a dxf file send by my client, will surely take a few hours.
Best answer by mneumueller
Dear Ratty and all,
The articles 369555 and 369607 have been updated. We hope that gives more background to the reasons and intent of the changed behavior.
In addition, we currently plan to add the "All-curves-in-feature" rule to the chain collection workflow in Creo 9.0.2. This should address the above mentioned workflows.
Only the product manager can answer the 'why'.  Do either of these articles help with your workflow?
Also check out this video:
Ratthy8-GravelAuthor
8-Gravel
May 26, 2022
Thanks for the video. I have made some try. The shift + right clic work perfectly on a 3d part edge.
But, because my client send me 2d DXF and DWG files, I open in in a part. And I have to sketch all his hole pattern on my model. But with line form a "Curve From File" feature, the shift + right mouse bouton does not work very well.
8-Gravel
May 26, 2022
By making test with a selection of 2d Curve from a import, select the fist line, then open immediately this selection windows. This help with the rapidity that the curve are selected.
Even I got frustrated with this change. I have to select each and every curve in sketch mode. Before it was easy with just one click on the sketch and the whole sketch would get projected. For example it would take a lifecycle to complete a loop of one logo of the particular company, to project on to the surface.
Does anyone have any solution to get rid of this issue and get the older way of projecting sketches?
I have the same problem. I really hope PTC improves the new project tool soon.
18-Opal
August 26, 2022
Dear Ratty and all,
I can't believe the Creo Team thought that this would be a better way to do things.
They've made it more tedious to select an entire loop and added some menu tax if you want to make that loop modifiable.
What once took two clicks, now takes far more clicks and time.
On top of this, they seem to have completely removed the ability to Project Loop from Sketch, which was invaluable in building up the complexity of a sketch without having to do everything all in one go.
Absolutely terrible update,
Thanks, voted
