CREO2 parametric.psf
- November 13, 2012
- 1 reply
- 2014 views
Our users are running a batch file to launch CREO2
For ½ the users this works for the other half they receive the error below. Their paths are correct?
The cmd C:\parametric doesn't work like C:\proe1 did?
copy "\\hqstor1\data\Shared\ProE Config\config.dtl" C:\prowork
copy "\\hqstor1\data\Shared\ProE Config\appearance.dmt" C:\prowork
copy "\\hqstor1\data\Shared\ProE Config\TABLE.PNT" C:\prowork
copy "\\hqstor1\data\Shared\ProE Config\config.sup" "C:\PTC\Creo2\Creo 2.0\Common Files\M020\text"
copy "\\hqstor1\data\Shared\ProE Config\config.pro" "C:\PTC\Creo2\Creo 2.0\Common Files\M020\text"
copy "\\hqstor1\data\Shared\ProE Config\parametric.psf" "C:\ptc\Creo2\creo 2.0\parametric\bin"
start "C:\ptc\Creo2\creo 2.0\parametric\bin\parametric" "C:\ptc\Creo2\creo 2.0\parametric\bin\parametric.psf" %*
exit
[cid:image002.png@01CDC18E.83E6A4E0]
exit
