CSV table separated by commas and not spaces
BC_10219589
I have been trying to add an excel table into a creo drawing and when I import the csv file into the drawing the data is separated by commas and I get only one-column table. Does anybody know how to fix this so that I get all the columns and a table that looks like to one I have in excel?
Thank you for your help.
@BC_10219589 wrote:
Thank you for your answer, however, I can't paste excel cells into my creo drawing (I am using Creo 7, 0.7.0)
do you know why this happens?
Thank you,
did you apply setting from https://www.ptc.com/en/support/article/CS355947 ?
Creo 7.0.7.0 & Excel 2016 on my PC works as expected. See video.
Martin Hanák
5 REPLIES 5
on my PC I applied setting from https://www.ptc.com/en/support/article/CS355947 .
In Creo 9.0.0.0 I am able to:
  • create empty Excel workbook in Creo drawing
  • open Excel file outside Creo
  • select cells
  • CTRL+C
  • double-click table in Creo drawing
  • CTRL+V
I do not need to export/import csv file.
Martin Hanák
Thank you,
Thank you,
Martin Hanák
Thank you very much, now it works. Do you know if there is any possibility of changing the font size and table widht/height? (once it's an excel table) The table I want to add is a very large one and I'm not sure if using this option I will be able to make it fit in one sheet and would like to control those parameters.
double-click the table ... Excel UI opens ... then do what you need.
Martin Hanák
