CSYS ASSY
pfadams
CSYS ASSY
I JUST DOWNLOADED A FILE FROM A VENDOR. THE PATR CAME IN AS A CSYS DEVELOPED PART, BUT MY ASS,Y IS NOT. HOW CAN I INSERT THIS PART INTO AN ASSY THAT IS NOT A CSYS ASSY.
CAN I TURN OFF THE CSYS?
THANX
PAUL
jstone
(To:pfadams)
Paul,
If your assembly does not have a csys (?????) but does have at least three default datums you can add a csys to the assy. On the import you can add a layer to hide the csys if there isn't a layer already there. You can also create datums in the import using the csys as the reference (X,Y, and Z).
Jeffrey Stone
Cable and Harness Integration Engineer
[cid:image003.jpg@01CBA1D2.5C61D2B0]
10 Mupac Drive
Brockton, MA 02301
jstone@sie-cs.com<">mailto:karen.maillet@nts.com>
Main: 508-588-6110, Ext. 207
Fax: 508-588-0498
Follow SIE on:
[cid:634322115@03082011-220F]<">http://www.facebook.com/pages/SIE-Computing-Solutions-Inc/196588810394816> [cid:634322115@03082011-2216] <">http://www.linkedin.com/company/sie-computing-solutions-inc> [cid:634322115@03082011-221D] <">http://twitter.com/#!/SIE_CS>
