I have routed a cable. How can I display the length of the cable in a table (i.e. what parameter captures the length of the cable)? Thank you.
-1,-1 is the correct format
I recall using a repeat region in the past that brought in the length values, but I can't remember if it was for a cable or a pipe. Does that ring a bell to anyone? I would think the repeat region would be calling for the same parameter.
Worked sweet. Everything created while in cabling mode (annotation and relation)!
