Cable wire marker tube (=label) and ferrule
Nicolas_
2-Explorer
Hi all,
I found Creo schematics software yesterday, and I think it would suit my needs but I would like to ask a few questions, if some members of the community has encountered the case already.
At my company we use to draw harness layout drawing (all connected harnesses of the project) on a single sheet. I believe this can be done using circuit diagram.
In our harnesses, we are using ferrules and mark tube (on which we print wire label) because harnesses are connected to terminal blocks.
My questions:
Is it possible to define ferrules and mark tubes when creatins harnesses? Is it a built-in function or can we develop it by ourselves?
Is there any terminal blocks templates already?
Thank in advance.
Nicolas
3 REPLIES 3
I use the variable connector feature although I think it originally came with a prepurchased symbol data base which kinda sucks and I have since modified it: here are some examples:
in the schematics help manual it tells you how to make them, I use the variable connector feature for terminal blocks all the time:
Hello @nv_12007380,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
