Cables not displayed in STEP files
mashton-2
Creating STEP files from WF4 but cables are not being displayed. I have tried a some different options but to no avail.
Does anybody have settings that make the cables display in the STEP file?
Is this something that is better in Creo?
There is a check box on the export STEP pop-up settings "Export cable surfaces"
4 REPLIES 4
mashton-2
(To:eflores-2)
That is one of the options I have tried but I still don't get cables displayed when I re-import the STEP file.
mashton-2
(To:mashton-2)
I also tried IGES but still no joy. Also looked at config options but couldn't find any relevant settings.
mashton-2
(To:mashton-2)
Ah! I found this:
There is an export option, to export cable surfaces.
However, it works correctly only since Creo Elements/Pro 5.0
For Pro/ENGINEER Wildfire a workaround was required, as the cable surfaces were only exported with the surface option and not with the solid option.
The workaround required setting config.pro option step_export_format ap214_cd and exporting in two steps (solid for models and surface for the cables).
See article CS66555 : Export of thick cables does not work for for interfaces such like IGES, STEP, CATIA V4 (.model), ACIS, Parasolid, UG in Pro/ENGINEER Wildfire 4.0
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS66555
Sounds a bit of a faff so for what I need to do it may be better to lay points down and sweep a protrusion along a datum curve.
