Cams with liftoff
gfraulini
Cams with liftoff
Hi all,
recently I made an assembly that required some cams with liftoff.
The problem is that when I done a dynamic analysis, Mechanism needed a lot of time.
So I made a simplified assembly where I tested some cases but I didn't see any slowdowns.
Do you have some suggest or trick?
Attachment made with Creo 3.
2 REPLIES 2
Are you doing a dynamic or a kinetic analysis? If you disable gravity, it helps a lot.
I've tried with and without gravity but it was the same...
