Alfonso
Not sure why you would want to export from Diagram to RSD, unless you are trying to gety away from Pro/Diagram and need to transfer existing files to the RSD format.
What version of RSD are you using? But I believe you have to be on RSD 8 or 9 to be able to do the export you are asking about.
In Reply to alfonso medina:
The local cablers here have some weird way of setting up their pro diagram
diagrams and I think that prevents us from exporting the diagrams over to
RSD. I got a couple of requests, maybe someone can help me out.
1)Can I get a simple diagram from anyone that I can use to show that
exporting from ProDiagram to RSD is possible? Pretty Please?
2)Do you buy your connector/spool databases from some where? does it come
with RSD (I'm thinking no)? Is it easy to make these as you go/need them?
What strategy should I take as we move from Diagram to RSD without a set of
connectors/spools/pins etc.
regards,
Alfonso
Marshall Sexton
Design Solutions
