Can I show cross section arrows in model
jkordas
7-Bedrock
Is there a way to show cross section arrows in the model. We send out models with annotations on them instead of 2d drawings and I have a cross section for one of the dimensions. It's difficult to see exactly where the dimension is coming from and the arrows would really help.
Thanks.
1 REPLY 1
DeanLong
(To:jkordas)
Create offset planes, name them with the section names you want. When the recipient wants to know the dimension of the section location have them look at the offset value of the plane.
If you want actual "arrows" then sketch them in on a perpendicular plane. Simple enough.
