I made a cut through an irregular IGS model as seen in the attached picture. Can pro/E create a curve around that edge (selected in RED) and then calculate it's centroid? I'd like to put a point at this centroid.
i'd like to make 2 x-sections, then create a point through their respective centroids, and connect these 2 points with an axis. I'm not sure if x-section analysis can do that.
