Can two text in a drawing be linked to one another?
smerhi
2-Explorer
I reference a part number in a note on my drawing. The same part number is also referenced in a table. I wanted to somehow link the two part numbers so that if I change the part number in the table it will automatically change in the note. Is this possible?
1 REPLY 1
MartinHanak
(To:smerhi)
in Creo Parametric 2.0 you can create parameter in part and call out this parameter in drawing note/table cell.
See uploaded data:
1.]
In ref_part_name.prt there is a relation pname=rel_model_name() which defines parameter pname.
2.]
In ref_part_name.drw tha parameter is called using &pname notation.
Martin Hanak
Martin Hanák
