Cannot Remove Surface From Drawing
nhall
I have imported a parasolid, which contains some inserts that have been interpreted as surfaces. An issue arises when I come to make the drawing. The inserts are permanently shown in every orientation. The below image shows what it looks like (this is not a section view) and I have tried the normal method of erasing the line using Edge Display but no cooperation from creo.
As this is a parasolid, it is all imported as a singular item so am unable to delete the individual faces/bodies.
Is there anything I am not thinking of?
Cheers,
Nick
tgriffin
(To:nhall)
Switch over to your layer tree.
Create a new layer.
Add the surfaces to your new layer (it might help to utilize your selection filter).
Then hide the new layer, and save the layer status.
6 REPLIES 6
tgriffin
(To:nhall)
You can set it so those surfaces are hidden in your layer tree.  If there is not already a layer for them, just create a layer with the surfaces on it and then hide that layer and save the display status.
nhall
(To:tgriffin)
Although it is acting like a surface, my model tree only contains an imported feature so no surfaces are actually selectable.
tgriffin
(To:nhall)
Create a new layer.
You may be able to just select the import feature to add to the layer...
Either way its probably only a single click for selection, and by selecting the quilt, rather than the whole import feature, it won't hide associated datums.
nhall
(To:tgriffin)
Got it! I didn't think it would let me select it as a quilt, as I thought creo thought it was combined with the rest of the solid body. created a new layer, quilt selection filter then selected the two inserts. Sorted!
