All of a sudden the ability to change a dimension by double clicking the dimension has stopped working on CREO 3. I have read some of the online comments from others, but can not get the dimension update working.
David,
-Is it about dimensions in part or drawings?
-Is there any change recent change in machine?
-Do you have config option graphics in config.pro list OR is the application launching in win32_gdi mode? In the past I have seen if config option graphics is set to wini32_gdi, dimension will not option edit pull down on double click.
There is a video in the responds to this product idea that may help:
Allow double click edit of dimension or tolerance value in drawing
Thanks, Dale
If you are talking about the tolerance, here is a product ideas:
Edit the tolerance of a dimension in drawing by using double click
Thanks, Dale
