Cannot flip chain direction in boundary blend
mmeyns
I'm having the problem that I am unable to flip the chain direction in a boundary blend.
The flip button is greyed out.
Kevin
(To:mmeyns)
My guess is that this is only used with something like a VSS where the direction along the trajectory curve is specified.
mbonka
(To:mmeyns)
Hello MAARTEN MEYNS
try to check sketch "second reference" for 1st and 2nd chain. This reference should be the same for both.
Not sure, if it will help you... it´s the first what came to my mind.
Milan Bonka
