I do not know how and why this is happening. I have M080 running. I cannot hide threads lines and "hidden line removal for quilt" is grayed out.
I have WF5/creo, and so it looks like you have different options. There's several settings that affect quilts, the one I mentioned, the one you mentioned, and there are some dwg (.dtl file) options also:
remove_cosms_from_xsecs yes
show quilts in total xsecs no
hlr for threads yes
thread _standard std_ansi_imp_assy
Hopefully these will get you what you want.
In your config.pro, try setting: hlr_for_quilts yes
Frank, I just got off the phone with PTC and the setting I had to change was "show_quilts_in_total_xsecs YES" in drawing properties. I also included your setting as well under conffig.pro. Just in case. You never know with Creo ...
One more thing. They told me if cross section is made without option "Include all qults" under Options tab, option "hidden line removal for quilts" will be grayed out as it was in my previous post.
hlr for threads yes
It was this one:
remove_cosms_from_xsecs | all |
Thank you everyone!
HOLD ON EVERYONE!
Actually, just both of us, Frank.
Forget what I wrote in previous posts. I found out this by pure "click" mistake. None of those previous settings work, but this one works for sure:
Actually, this just removes cosmetics on every hole. BLAH! Still looking.
After changing "hlr_for_quilts yes" did you redo the section? (change to No Section, apply, then pick the section again.).
Matt, I even redo the whole cross section again and it did not help.
Hi Danilo !
Your post helped me a lot !
Thanks for sharing !!!
You are welcome.
There is a BUG in Creo when working with cross sections and "LOCAL" option is selected. Everyhing works fine with cross section option "FULL". I guess, PTC does not have a way to disable this BUG as an option .
And then, my productivity went down, trying to find a solution for quirks Creo has ... that shouldn't be there in first place. Does anyone checks anything in PTC prior release?
