Cannot save an assembly after changing a parameter
Hidetaka
I ran into a large assembly that I cannot save after changing some parameters.
The parameter does not seem to have anything to do with regenerating the assembly (it is date and designer name).
From the warning messages that appear after I tried to save the model, I have found 2 support articles, but I could not read them. Could someone please tell me what is in these two articles? Thank you so much!
https://www.ptc.com/en/support/article/CS258240
https://www.ptc.com/en/support/article/CS112336
The first (CS258240) indicates it is a result of regeneration failing. The "Resolution" in this case is:
Hello @hidetaka
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
