Cannot select a vertex for point-on-surface constraint
gchampoux
7-Bedrock
We need to insert a component to an assembly.
One of the contraints needed will be point-on-surface.
The vast majority of the time, we have no difficulty doing this.
However, for a few of our assemblies, we are seeing odd behavior.
The user cannot select
More info:
This problem is only happening on one PC. (and only a few assemblies on that PC)
We've re-installed CE Pro, and tried several graphic drivers (Quadro 3450) to no avail.
We have confirmed that point-on-surface still works with datum points, but not vertices on solids.
Until we figure our a solution, the work-around is to create a datum point on the needed vertex.
Gerry Champoux
Williams International
Walled Lake, MI
In Reply to Gerry Champoux:
Problem solved.
Look at what I found in the user's config.pro file:
any vertex in the the assembly (any part within) or in the new component.
Nothing pre-highlights either. Selecting the surface always works as expected, but not the point/vertex.
We've played with dirreent selection filters to no avail.
Again, this affects only a few assemblies.
I found nothing about this at the PTC knowledgebase.
Anyone else seen this odd behavior?
We are using Creo Element Pro 5 (Wildfire 5) M120.
