Cero Material Files
cdown
7-Bedrock
Cero Material Files
Gurus.
I have been trying without much luck to add a parameter field to a
material file.
ie, the start part has a parameter of material, what I am trying to achive
is that when a material is assigned to the part this parameter is
automatically filled in.
How do you do about doing I have tried several times but just can't seam
to get this to work.
Also can you assign colours and appearances to a material file so when you
assign it the model will up date to the correct colour and appearance,
again I can't seam to get this to work properly!!
Any help would be greatly received
Colin Down
Mechanical Design Engineer
email: -
tel: +44 1305 208503
The information in this e-mail and any attachments transmitted with it are provided in commercial confidence for the intended recipient(s). If you have received this e-mail in error, please notify the Postmaster by e-mail at -. Any views or opinions expressed are solely those of the author and do not necessarily represent those of DEK.
For local company specific legal information for your country or region and any local contact information for DEK, please refer to:
0 REPLIES 0
