Change the rename feature/geometry command back to what it WAS.
Patriot_1776
This is from my other thread:
http://communities.ptc.com/message/181326
I had "Geometry Points" I made in a datum curve, and I wanted to rename the points individually, not the sketch, and it took me hours to find the way to do it, whereas I had a simple mapkey before and i cold pick "Other" and rename anything I wanted.
If you're in a top assembly, and ANY feature or buried feature you want to rename is in a part or lower-level assembly, you must either OPEN that assembly and do it there, or ACTIVATE the part or lower-level assembly where the feature resides. So, you have to do all this, AND scroll thru 2 separate menus containing ALL the many features in a part (some of mine have had 1,400+ features!) to get to a simple rename, instead of just doing it?!?!?! Wow. Can't wait to be done with these changes so I can go back on WF4.
Change it back to the way it USED to be where we can simply PICK what we want, not have to scroll through potentially THOUSANDS of features to find the one we want to rename.
Ok, so, I THOUGHT I'd put this in the "Ideas" section. Ah well, who cares....
