Change the symbol from arrow to dot on note leader
jlecointre
Hello all,
I'm searching how to replace the standard "arrow head" of a Pro/Piping note leader (bend number) by a dot, which I find more convenient to designate the intersection points at bends locations.
I have found parameter in the ".dtl" file to select the kind of arrow head (filled or hollow), its size, and also the size of dots, but not the way to have dots instead of the arrow heads on a standard basis.
Many thanks advanced.
Kind regards. Jean-Michel.
1 REPLY 1
You may be looking for the .dtl option "default_leader_arrow_style" this is set to "automatic" by default but can be set to dot, arrow, nothing.
Andy Hermanson
Engineering Design Applications
tel 605.275.1040 x51114 mobile 605.951.0168
website www.daktronics.com
