Hello all,
I'm searching how to replace the standard "arrow head" of a Pro/Piping note leader (bend number) by a dot, which I find more convenient to designate the intersection points at bends locations.
I have found parameter in the ".dtl" file to select the kind of arrow head (filled or hollow), its size, and also the size of dots, but not the way to have dots instead of the arrow heads on a standard basis.
Many thanks advanced.
Kind regards. Jean-Michel.
