Changing a BOM
dbolden
8-Gravel
Changing a BOM
I want to change Item 1 of my BOM away from the actual part number to "See Note 1".  If I delete the value in the cell it deletes the following BOM components.  I would also like to change the description from it's part name.  Both of these fields appear to be uneditable.  When I right click the field it has "edit value" but that does nothing.  It doesn't even bring up a place to change.  This is the last item I need to align.
1 REPLY 1
You need to change the parameter within the part to be "see note one". If you are using the model name as your parameter, you need to add a parameter to be used instead on all your parts.
Otherwise, you can add a row and put item one in it. Then exclude item one in your repeat region and do a fix index to start your repeat region area at 2. (in other words, fake row one)
