Is there any way Model check identity and alert any views that are placed outside the format.
Many a times designers move few views temporarily outside the format for a specific purpose and forget to remove or move back them later.
Manjunath,
I think View Boundaries can help you here. Set ModelCHECK parameter BOUND_INFO as E in respective check file.
This will report error when any of the view is outside the boundary of a drawing.
Note: This check considers the boundary of drawing, not the boundary of format for analysis.
Manjunath,
Thanks Mahesh, I will check and reply back.
Perfect!! ![]()
This was what i was looking for. Thanks Mahesh ![]()
