I recently began to see the circles in my drafts as polygons (see image attached). It began since:
1. I have a new ultra wide monitor
2. run some updates on my computer.
It's only an issue when in draft or sketch mode, other programs are not affected (like when exporting a draft to PDF).
I'm using Creo version 8.0.3.0
Thank you in advance for any help.
Found the solution:
Added edge_tess_quality to the config.pro file.
Hey there!
There's another fix to the problem encountered herein; following the below steps might solve it:
1. go to file
2. Click on Prepare
3. Click on model properties
4. Alter the accuracy to 0.01
This works in my case
