Do you have admin rights on your workstation?
Use "Run as Adminitstrator" on Setup.exe.
To use Run as Administrator. It still doesn't work. Run setup as an administrator. The cursor circles and there is no response. I have tried many times. It has been turned off. Firewall, security mode
please publish hardware configuration of your computer + operating system version.
Hi @志莫_14376332,
Anurag
Copy the installation files to a different location, such as C:\temp and run it from there. You probably have a special character in the current path.
