Color of placement handles
ptc-2373
Using Creo 8.0.
Is there a way to change the color of the hole placement handles ? ( the symbols you drag to define XY placement of a hole on a selected surface). By default it is red, but is hard to see when superimposed on the selected placement surface that also turns red upon selection.
See attached screenshot in where I refer to the symbol at the end of the striped red line.
you can modify below mentioned files.
Martin Hanák
1 REPLY 1
Martin Hanák
