I am looking for info on the best ways to work with Combinations States to make both 2D and 3D drawings.
I also havea question\issue regarding showing dimensioned combination state "views"on drawings.
I have a part with a section view. The Front View of the part and the section view have thesame orientation. When I show the front view combination state, the dimensions from the section view show up with the rest of the front view dimensions. In the model the section view dimensions are only in the section view combination state.
Thanks for any and all help.
David
David,
I believe it is a config.dtl option called allow_3d_dimension. I think it needs to be set to NO.
