Combined Views
gfraulini
Combined Views
Hi all,
I wondered how can I automatically set this setting activated at the start of the program (WF5).
I have not found the option for the config.pro, and setting that on the config.win doesn't work.
Bye
Hi Giulio,
Unfortunately, the Display Combined Views option does not retain its setting between sessions and there is no config.pro option to control it in Creo Elements/Pro 5.0.  You can create a mapkey that toggles the option through View > Display Combined Views menu.
As of Creo 2.0, a config option has been added to control this - display_combined_views.  The default value is no and the description for the option is Display combined view tabs by default.
Amit
Hi Giulio,
Amit
