Common name
bmozley
Common name
Creo Community,
While creating a new part, below the "name" box is "common name". What
is common name
and how is it used?
Brad
Creo 2.0 M010
3 REPLIES 3
Common Name is used primarily in Windchill (where it is called "name"
confusingly). It allows you to use punctuation, spaces, capitalisation
etc to give the part/asm/drawing a more descriptive title. You can access
it in drawing title blocks (or any other notes) using &PTC_COMMON_NAME:D
(this will display the common name of the drawing, drop the 😄 to display
the common name of the active part.
cheers
Mark von Huben
Cochlear Ltd
MikeLockwood
22-Sapphire I
(To:bmozley)
See either of these doc’s.
It’s horrible that this confusing situation still exists.
Useful only with Windchill really
The basic idea is name=number in Windchill and common name=name in Windchill
